Community Member
DID --- Dial Plan Vs TCL Script
Hi all
I am planning to implement a CCME/CUE solution for a client.
I have an ISDN PRI and i won't to finalize the implementation for the DID.
Which method is more recommended/flexible between implementing DID via a dial plan from the telephony service configuration or using the Cisco TCL script for DID.
Your comment will be much appreciated.
Nour
Hall of Fame Super Gold
Re: DID --- Dial Plan Vs TCL Script
the script is only used when DID from telco and internal numbering don't match. Normally you use only dialplan command or sometime a translation-rule.
Community Member
Great thanks!
146
