DID extension Dial Out Problem
We are using Call Manager business Ed.6.1 , Cisco3845 E1PRI gateway and have 500 DID. The problem is when we dial from DID extension to outside PSTN users the extension number not displayed on the end user phone onlu the first number displayed for every call
DID 5000-5499, ext. 5200 calls to 3456780 pst number , the number displayed on the PSTN user phone is 5000 not 5200.
Re: DID extension Dial Out Problem
Verify with your Telco that CLIP is enabled, if CLIP is not enabled that the default billing number for the circuit will advised in most cases.
Verify that your gateway endpoint does not have CLI presentation set to restricted. By default it is set to allowed.
Incidentally, have you configure an external phone mask on yur DNs?
If you have, then also verify that you have either set the use users external phone mask to ON within the route-list and in the particular route-group details or alternatively on the specific route-pattern?
If left to the system default within the route-list/group details, CUCM will use the route-pattern preference instead. The simplest option would be to change route-list/group details to ON.
Rgds
Allan.
Thanks ,..
I have done this. In the Voice Gateway when i debug ISDN Q931 , Voice CCAPI out.
It is showing called number = 5200
calling number = 3654566
But when the call lands in End user it shows 5000 pilot number. Also in the debug information it says Transform number is blank
Incidentally, I initially assumed your gateway was MGCP, or are you are using H323?
If the later is the case, have you applied any outgoing voice translation rule to your POTs dial-peer.
Please post your configuration.
Allan.
ontroller E1 0/0/0
pri-group timeslots 1-31 service mgcp
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-4ess
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
control-plane
voice-port 0/0/0:15
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.190.10.2
ccm-manager config
mgcp
mgcp call-agent 10.190.10.2 2427 service-t
mgcp dtmf-relay voip codec all mode out-of
mgcp rtp unreachable timeout 1000 action n
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 1999 pots
service mgcpapp
incoming called-number 30705...
direct-inward-dial
port 0/0/0:15
dial-peer voice 1 voip
destination-pattern 5...
session target ipv4:10.190.10.2
codec g711alaw
We have the same issue on some of our sites. Turned out to be our service provider
259
