02-26-2008 01:20 PM - edited 03-15-2019 09:05 AM
We presently have a configuration that allows our receptionist to transfer calls across a tie line to a specific extension ( 8 access code) extension 7059. we would like to transfer/Forward a DID 5546, when called externally or internally across the tie to the same extension. How can this be accomplished, without terminating on a IPT phone.
02-26-2008 07:13 PM
Hi James,
You could set up a CTI RP with the DN 5546 and set the Call Forward All to 87059.
Hope this helps!
Rob
02-27-2008 06:50 AM
not that familiar with creating a CTI RP, is there a link that would give an example of the setup. Also, could this be done via a translation table. if so could you provide and example. Thanks
02-27-2008 07:35 AM
Hi James,
Sorry about that, I should have sent a link :) These are quick to setup and a nice way to route a "virtual" number without an actual phone.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmcfg/b06ctirp.html
I just set one up for testing and it took only a few mniutes. Don't forget to set the Call Forward All after the DN has been inserted.
Hope this helps!
Rob
