Community Member
DID in E1
How to config DID in E1?
Hall of Fame Super Gold
Re: DID in E1
Do you have PRI, and do you have callamanager, or what ?
Community Member
Re: DID in E1
I have PRI and also have CCM. I want to translate PSTN no. to internal extension no.
Example. PSTN no. xx-xxx-xxxx translate to internal extension no. yyyy
How to config in voice gateway router, or setting in CCM is more flexible ?
Community Member
Re: DID in E1
My system is C3845 with VWIC2-1MFT-T1/E1 IOS 12.4 and 4FXS-DID CCM 6.0
Re: DID in E1
If you use mgcp, all the config is in the ccm.
If using h.323 or sip, you can config in router, ccm, or both.
Community Member
Re: DID in E1
If I used h.323, I need to create translation rule into gateway router for DID or any other solution ?
thank you.
Re: DID in E1
As mentioned above, you can have the translation done either the router, or in the ccm. Really it depends on what you like better to configure.
Community Member
Re: DID in E1
I'm in a similar problem. I have CCME running on a C2851 with a VWIC-1MFT-G703. The Telco is providing 30 DID numbers through an E1 connection. (58500800 to 58500829)
At this time all calls are ringing to operator because I set a "connection plar" command in the voice-port 0/0/0:1 which is the VWIC card.
I understand I should define DID numbers as secondary numbers in the corresponding ephone-dn's. I tried but unsucessfully. So, I guess I'm missing something.
Thanks in advance
Re: DID in E1
No is not said that you have to create secondary numbers.
You can also use dialplan-pattern under telephony-service.
The syntax of the command really depends on how you configured the extensions numbers.
Another alternative is translation-profile and rule under voice-port.
265
