Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
DID issue....
We have implemented DID in our network. We are having 3845 gateway router and using H.323 as gateway protocol. Now the problem is when someone is calling from outside to a DID number the call is coming and caller id is visible but when a call is made from a DID number to outside (Mobile number) the call is going but the particular DID number is not showing in the cell phone instead the pilot number is showing and the problem is same for all the DID numbers configured in the network. So is there any configuration related issue??? Please suggest... The configuration that we made in the GW router for DID is follows -
controller E1 0/1/1
framing NO-CRC4
pri-group timeslots 1-31
description *** DID PRI ***
interface Serial0/1/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
voice-port 0/1/1:15
cptone IN
dial-peer voice 5 pots
description *** Outgoing calls to PSTN ***
preference 3
destination-pattern .T
no digit-strip
direct-inward-dial
port 0/1/1:15
forward-digits all
dial-peer voice 6 voip
destination-pattern 2213....
session target ipv4:XXX.XXX.XX.X
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
no vad
Everyone's tags (1)
DID issue....
It seems that you dont send the correct dids out to the PSTN.
You have to talk with your ISP and adviced you how many digits for the A number(you extension) wating for
If are not match then you will have only the pilot A number
chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
DID issue....
We are in a constant touch with ISP, but they are saying that configuration at their end is fine, and there might be some problem at our end..
VIP Super Bronze
DID issue....
What number are you presenting to your ISP? You need to present your full DDI. Do you have external number mask set on your phones or do you have translation rules to change your calling number from internal extensions to your DDI?
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
DID issue....
Thanx for your reply...
We are presenting full DDI.. No we dont have any external number mask instead we have translation rules.
VIP Super Bronze
DID issue....
Can you do a test call and send the following:
debug voip ccapi inout
DID issue....
Please find the debug output below -
VOICE-GATEWAY#
*Aug 27 09:49:58.717: //-1/800AC5A39263/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=22139515 ( DID Number)
   ----- ccCallInfo IE subfields -----
   cisco-ani=22139515
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=9831750967 --------> Called Number
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Aug 27 09:49:58.717: //-1/800AC5A39263/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x680D99F8, Call Info(
   Calling Number=22139515,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=9831750967(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=6, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=794942
*Aug 27 09:49:58.717: //-1/800AC5A39263/CCAPI/ccCheckClipClir:
   In: Calling Number=22139515(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=22139515(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
*Aug 27 09:49:58.717: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Aug 27 09:49:58.717: :cc_get_feature_vsa malloc success
*Aug 27 09:49:58.717:  cc_get_feature_vsa count is 9
*Aug 27 09:49:58.717: :FEATURE_VSA attributes are: feature_name:0,feature_time:1770571488,feature_id:794942
*Aug 27 09:49:58.717: //794942/800AC5A39263/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=22139515(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=9831750967(TON=Unknown, NPI=Unknown))
*Aug 27 09:49:58.717: //794942/800AC5A39263/CCAPI/cc_process_call_setup_ind:
   Event=0x68875610
*Aug 27 09:49:58.717: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 9831750967
*Aug 27 09:49:58.717: //794942/800AC5A39263/CCAPI/ccCallSetContext:
   Context=0x694DC770
   >>>>CCAPI handed cid 794942 with tag 6 to app "_ManagedAppProcess_Default"
*Aug 27 09:49:58.717: //794942/800AC5A39263/CCAPI/ccCallProceeding:
*Aug 27 09:49:58.717: //794942/800AC5A39263/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1, Params=0x692C8EC8, Progress Indication=NULL(0)
*Aug 27 09:49:58.717: //794942/800AC5A39263/CCAPI/ccCheckClipClir:
   Destination Pattern=.T, Called Number=9831750967, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=22139515, Final Destination Flag=TRUE,
   Guid=800AC5A3-F247-B103-9263-0303C0A897B6, Outgoing Dial-peer=1
*Aug 27 09:49:58.717: //794942/800AC5A39263/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=22139515
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=9831750967
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Re: DID issue....
The actual called number is 831750967  ? or 9831750967
The issue is with local called numbers? international called numbers?
I believe that may you have to use in your translation rule a rule for the A number and manipulate the plan and the type
But in any case the ISP should advice you what are they expecting for A and B number(calling and called number)
for example:
Here any extension will dial outside and the type from unknown will be national and the plan from unknown will be isdn
If it work for the national numbers may you have to create another one pots dial peer and another one translation profile for the international called numbers
voice translation-rule 6
rule 1 / /  / / type unknown national plan unknown isdn
voice translation-profile OUTGOING
translate calling 6
cc
VIP Super Bronze
DID issue....
So you are saying that 22139515 is part of your DDI range?
Can you place an inbound call to this number and send me the debugs too..That way we know that this number is reachable from outside.
Also in your debug I cant see the translated number. This looks like the internal extension on the phone.
DID issue....
Yes 22139515 is a part of DDI range.
I have placed an inbound call. The dubug result is as follows -
*Aug 27 10:30:55.133: //-1/1DF9C48EB32E/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=9674168877---------> Called from this number
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=22139523
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Aug 27 10:30:55.133: //-1/1DF9C48EB32E/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x69203AAC, Call Info(
   Calling Number=9674168877,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=22139523(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Aug 27 10:30:55.133: //-1/1DF9C48EB32E/CCAPI/ccCheckClipClir:
   In: Calling Number=9674168877(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=9674168877(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
*Aug 27 10:30:55.133: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Aug 27 10:30:55.133: :cc_get_feature_vsa malloc success
*Aug 27 10:30:55.133:  cc_get_feature_vsa count is 5
*Aug 27 10:30:55.133: :FEATURE_VSA attributes are: feature_name:0,feature_time:1770569024,feature_id:795129
*Aug 27 10:30:55.133: //795129/1DF9C48EB32E/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=9674168877(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=22139523(TON=Subscriber, NPI=ISDN))
*Aug 27 10:30:55.133: //795129/1DF9C48EB32E/CCAPI/cc_process_call_setup_ind:
   Event=0x68875610
*Aug 27 10:30:55.133: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 22139523
*Aug 27 10:30:55.133: //795129/1DF9C48EB32E/CCAPI/ccCallSetContext:
   Context=0x69946564
   >>>>CCAPI handed cid 795129 with tag 1 to app "_ManagedAppProcess_Default"
*Aug 27 10:30:55.137: //795129/1DF9C48EB32E/CCAPI/ccCallProceeding:
*Aug 27 10:30:55.137: //795129/1DF9C48EB32E/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=6, Params=0x694DA1B0, Progress Indication=NULL(0)
*Aug 27 10:30:55.137: //795129/1DF9C48EB32E/CCAPI/ccCheckClipClir:
   Destination Pattern=2213...., Called Number=22139523, Digit Strip=FALSE
   Account Number=, Final Destination Flag=TRUE,
   Guid=1DF9C48E-EF69-11E1-B32E-002545736C90, Outgoing Dial-peer=6
*Aug 27 10:30:55.137: //795129/1DF9C48EB32E/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=22139523
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Aug 27 10:30:55.137: //795129/1DF9C48EB32E/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x680D99F8, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=9674168877,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=22139523(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=6, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Aug 27 10:30:55.137: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Aug 27 10:30:55.137: :cc_get_feature_vsa malloc success
*Aug 27 10:30:55.137:  cc_get_feature_vsa count is 6
*Aug 27 10:30:55.137: :FEATURE_VSA attributes are: feature_name:0,feature_time:1770574624,feature_id:795130
*Aug 27 10:30:55.137: //795130/1DF9C48EB32E/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
*Aug 27 10:30:55.137: //795130/1DF9C48EB32E/CCAPI/ccCallSetContext:
   Context=0x694DA160
*Aug 27 10:30:55.137: //795129/1DF9C48EB32E/CCAPI/ccSaveDialpeerTag:
*Aug 27 10:30:55.149: //795130/1DF9C48EB32E/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
*Aug 27 10:30:55.149: //795130/1DF9C48EB32E/CCAPI/cc_api_call_proceeding:
   Interface=0x680D99F8, Progress Indication=NULL(0)
*Aug 27 10:30:55.153: //795130/1DF9C48EB32E/CCAPI/cc_api_set_called_ccm_detected:
*Aug 27 10:30:55.153: //795130/1DF9C48EB32E/CCAPI/cc_api_set_delay_xport:
   CallInfo(delay xport=TRUE)
*Aug 27 10:30:55.153: //795130/1DF9C48EB32E/CCAPI/cc_api_call_alert:
   Interface=0x680D99F8, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
*Aug 27 10:30:55.153: //795129/1DF9C48EB32E/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
*Aug 27 10:30:55.153: //795129/1DF9C48EB32E/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
   Tone Direction=Network, Params=0x0, Call Id=795129
*Aug 27 10:30:55.349: //795130/1DF9C48EB32E/CCAPI/cc_api_set_called_ccm_detected:
*Aug 27 10:30:55.349: //795130/1DF9C48EB32E/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x680D99F8, Call Id=795130
*Aug 27 10:30:55.349: //795130/1DF9C48EB32E/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
*Aug 27 10:30:55.349: //795130/1DF9C48EB32E/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
*Aug 27 10:30:55.349: //795129/1DF9C48EB32E/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=795129
*Aug 27 16:00:57: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 9433736798 N/A
*Aug 27 10:30:57.201: //795128/006F1A55D863/CCAPI/cc_api_call_connected:
   Interface=0x688C4BA4, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*Aug 27 10:30:57.201: //795127/006F1A55D863/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
*Aug 27 10:30:57.201: //795128/006F1A55D863/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
   Call Entry(Connected=TRUE, Responsed=TRUE)
*Aug 27 10:31:00.093: //795130/1DF9C48EB32E/CCAPI/ccIsInfoRingback:
   Returning dpRingBack=0
*Aug 27 10:31:00.245: //795130/1DF9C48EB32E/CCAPI/cc_api_call_connected:
   Interface=0x680D99F8, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
*Aug 27 10:31:00.245: //795130/1DF9C48EB32E/CCAPI/cc_api_set_called_ccm_detected:
*Aug 27 10:31:00.245: //795130/1DF9C48EB32E/CCAPI/cc_api_call_notify:
*Aug 27 10:31:00.245: //795129/1DF9C48EB32E/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
*Aug 27 10:31:00.245: //795129/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x6980634C, callID1=0xC21F9, callID2=0xC21FA, tag=0x0)
   (confID=0x6980634C, callID1=0xC21F9, gcid=1DF9C48E-EF6911E1-B32E0025-45736C90, tag=0x0)
*Aug 27 10:31:00.245: //795130/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x6980634C, callID2=0xC21FA, gcid=1DF9C48E-EF6911E1-B32E0025-45736C90, tag=0x0)
*Aug 27 10:31:00.245: //795129/1DF9C48EB32E/CCAPI/ccConferenceCreate:
   Conference Id=0x6980634C, Call Id1=795129, Call Id2=795130, Tag=0x0
*Aug 27 10:31:00.245: //795129/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x4CB61, Source Interface=0x69203AAC, Source Call Id=795129,
   Destination Call Id=795130, Disposition=0x0, Tag=0xFFFFFFFF
*Aug 27 10:31:00.245: //795130/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Aug 27 10:31:00.245: cc_api_get_xcode_stream : 4534
*Aug 27 10:31:00.245: //795130/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x4CB61, Source Interface=0x680D99F8, Source Call Id=795130,
   Destination Call Id=795129, Disposition=0x0, Tag=0x0
*Aug 27 10:31:00.245: //795129/1DF9C48EB32E/CCAPI/cc_generic_bridge_done:
*Aug 27 10:31:00.249: //795129/1DF9C48EB32E/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x4CB61, Destination Call Id=795130)
*Aug 27 10:31:00.249: //795130/1DF9C48EB32E/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x4CB61, Destination Call Id=795129)
*Aug 27 10:31:00.249: //795129/1DF9C48EB32E/CCAPI/cc_api_caps_ind:
   Destination Interface=0x680D99F8, Destination Call Id=795130, Source Call Id=795129,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
*Aug 27 10:31:00.249: //795129/1DF9C48EB32E/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x4CB61, Call Id1=795129, Call Id2=795130
*Aug 27 10:31:00.249: //795130/1DF9C48EB32E/CCAPI/cc_api_caps_ind:
   Destination Interface=0x69203AAC, Destination Call Id=795129, Source Call Id=795130,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
*Aug 27 10:31:00.249: //795130/1DF9C48EB32E/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=188)
*Aug 27 10:31:00.249: //795129/1DF9C48EB32E/CCAPI/cc_api_caps_ack:
*Aug 27 10:31:00.249: //795130/1DF9C48EB32E/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
*Aug 27 10:31:00.249: //795130/1DF9C48EB32E/CCAPI/cc_api_get_ccm_detected:
*Aug 27 10:31:00.249: //795129/1DF9C48EB32E/CCAPI/ccCallNotify:
*Aug 27 10:31:00.249: //795129/1DF9C48EB32E/CCAPI/cc_api_voice_mode_event:
   Call Id=795129
   Call Entry(Context=0x69946564)
*Aug 27 10:31:00.249: //795129/1DF9C48EB32E/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x0
*Aug 27 16:01:00: %ISDN-6-CONNECT: Interface Serial0/1/1:10 is now connected to 9674168877 N/A
*Aug 27 10:31:03.805: //-1/00310661A663/CCAPI/cc_api_display_ie_subfields:
   cisco-username=22139516
   cisco-ani=22139516
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=09435562844
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Aug 27 10:31:03.805: //-1/00310661A663/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=22139516,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=09435562844(TON=Unknown, NPI=Unknown),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=795131
*Aug 27 10:31:03.805: //-1/00310661A663/CCAPI/ccCheckClipClir:
   In: Calling Number=22139516(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=22139516(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
*Aug 27 10:31:03.805: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Aug 27 10:31:03.805: :cc_get_feature_vsa malloc success
*Aug 27 10:31:03.805:  cc_get_feature_vsa count is 7
*Aug 27 10:31:03.805: :FEATURE_VSA attributes are: feature_name:0,feature_time:1770572608,feature_id:795131
*Aug 27 10:31:03.805: //795131/00310661A663/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=22139516(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=09435562844(TON=Unknown, NPI=Unknown))
*Aug 27 10:31:03.809: //795131/00310661A663/CCAPI/cc_process_call_setup_ind:
   Event=0x68876A20
*Aug 27 10:31:03.809: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 09435562844
*Aug 27 10:31:03.809: //795131/00310661A663/CCAPI/ccCallSetContext:
   Context=0x692CDA98
   >>>>CCAPI handed cid 795131 with tag 6 to app "_ManagedAppProcess_Default"
*Aug 27 10:31:03.809: //795131/00310661A663/CCAPI/ccCallProceeding:
*Aug 27 10:31:03.809: //795131/00310661A663/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=1, Params=0x69870174, Progress Indication=NULL(0)
*Aug 27 10:31:03.809: //795131/00310661A663/CCAPI/ccCheckClipClir:
   Destination Pattern=.T, Called Number=09435562844, Digit Strip=FALSE
   Account Number=22139516, Final Destination Flag=TRUE,
   Guid=00310661-9351-B103-A663-1A07C0A897B9, Outgoing Dial-peer=1
*Aug 27 10:31:03.809: //795131/00310661A663/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=22139516
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=09435562844
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Aug 27 10:31:03.809: //795131/00310661A663/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x688C4BA4, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=22139516,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=09435562844(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1, Call Count On=FALSE,
*Aug 27 10:31:03.809: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Aug 27 10:31:03.809: :cc_get_feature_vsa malloc success
*Aug 27 10:31:03.809:  cc_get_feature_vsa count is 8
*Aug 27 10:31:03.809: :FEATURE_VSA attributes are: feature_name:0,feature_time:1770569248,feature_id:795132
*Aug 27 10:31:03.809: //795132/00310661A663/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*Aug 27 10:31:03.809: //795132/00310661A663/CCAPI/ccCallSetContext:
   Context=0x69870124
*Aug 27 10:31:03.809: //795131/00310661A663/CCAPI/ccSaveDialpeerTag:
*Aug 27 10:31:04.033: //795132/00310661A663/CCAPI/cc_api_call_proceeding:
   Interface=0x688C4BA4, Progress Indication=NULL(0)
*Aug 27 10:31:05.301: //795132/00310661A663/CCAPI/cc_api_call_alert:
   Interface=0x688C4BA4, Progress Indication=NOT END TO END ISDN(1), Signal Indication=SIGNAL RINGBACK(1)
*Aug 27 10:31:05.301: //795131/00310661A663/CCAPI/ccCallAlert:
*Aug 27 10:31:05.301: //795132/00310661A663/CCAPI/cc_api_get_called_ccm_detected:
*Aug 27 10:31:05.301: //795131/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x6958B024, callID1=0xC21FB, callID2=0xC21FC, tag=0x0)
   (confID=0x6958B024, callID1=0xC21FB, gcid=0-0-0-0, tag=0x0)
*Aug 27 10:31:05.301: //795132/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x6958B024, callID2=0xC21FC, gcid=0-0-0-0, tag=0x0)
*Aug 27 10:31:05.301: //795131/00310661A663/CCAPI/ccConferenceCreate:
   Conference Id=0x6958B024, Call Id1=795131, Call Id2=795132, Tag=0x0
*Aug 27 10:31:05.301: //795131/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Aug 27 10:31:05.301: cc_api_get_xcode_stream : 4534
*Aug 27 10:31:05.301: //795131/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x4CB62, Source Interface=0x680D99F8, Source Call Id=795131,
   Destination Call Id=795132, Disposition=0x0, Tag=0x0
*Aug 27 10:31:05.301: //795132/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x4CB62, Source Interface=0x688C4BA4, Source Call Id=795132,
   Destination Call Id=795131, Disposition=0x0, Tag=0xFFFFFFFF
*Aug 27 10:31:05.301: //795131/00310661A663/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x4CB62, Destination Call Id=795132)
*Aug 27 10:31:05.301: //795132/00310661A663/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x4CB62, Destination Call Id=795131)
*Aug 27 10:31:05.305: //795132/00310661A663/CCAPI/cc_api_caps_ind:
   Destination Interface=0x680D99F8, Destination Call Id=795131, Source Call Id=795132,
*Aug 27 10:31:05.305: //795131/00310661A663/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
*Aug 27 10:31:05.305: //795131/00310661A663/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x4CB62, Call Id1=795131, Call Id2=795132
*Aug 27 10:31:05.305: //795131/00310661A663/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=795131
*Aug 27 10:31:05.305: //795132/00310661A663/CCAPI/cc_api_get_called_ccm_detected:
*Aug 27 10:31:05.809: //795131/00310661A663/CCAPI/cc_api_caps_ind:
   Destination Interface=0x688C4BA4, Destination Call Id=795132, Source Call Id=795131,
*Aug 27 10:31:05.809: //795131/00310661A663/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=4408)
*Aug 27 10:31:05.813: //795132/00310661A663/CCAPI/cc_api_caps_ack:
*Aug 27 10:31:05.813: //795132/00310661A663/CCAPI/cc_api_voice_mode_event:
   Call Id=795132
   Call Entry(Context=0x69870124)
*Aug 27 10:31:12.261: //795131/00310661A663/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x680D99F8, Call Id=795131
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
*Aug 27 10:31:12.261: //795131/00310661A663/CCAPI/ccConferenceDestroy:
   Conference Id=0x4CB62, Tag=0x0
*Aug 27 10:31:12.261: //795131/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*Aug 27 10:31:12.261: //795132/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=795131, Disposition=0x0, Tag=0x0
*Aug 27 10:31:12.261: //795131/00310661A663/CCAPI/cc_generic_bridge_done:
*Aug 27 10:31:12.261: //795132/00310661A663/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Aug 27 10:31:12.261: //795132/00310661A663/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Aug 27 10:31:12.261: //795131/00310661A663/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
*Aug 27 10:31:12.261: //795131/00310661A663/CCAPI/cc_api_get_transfer_info:
*Aug 27 10:31:12.273: //795131/00310661A663/CCAPI/cc_api_get_transfer_info:
*Aug 27 10:31:12.273: //795131/00310661A663/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x680D99F8, Tag=0x0, Call Id=795131,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Aug 27 10:31:12.273: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Aug 27 10:31:12.273: :cc_free_feature_vsa freeing 6988CB38
*Aug 27 10:31:12.273:  vsacount in free is 7
*Aug 27 10:31:12.393: //795132/00310661A663/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x688C4BA4, Tag=0x0, Call Id=795132,
*Aug 27 10:31:12.393: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Aug 27 10:31:12.393: :cc_free_feature_vsa freeing 6988BE18
*Aug 27 10:31:12.393:  vsacount in free is 6
*Aug 27 10:31:12.649: //795130/1DF9C48EB32E/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x680D99F8, Call Id=795130
*Aug 27 10:31:12.653: //795129/1DF9C48EB32E/CCAPI/ccConferenceDestroy:
   Conference Id=0x4CB61, Tag=0x0
*Aug 27 10:31:12.653: //795129/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=795130, Disposition=0x0, Tag=0x0
*Aug 27 10:31:12.653: //795130/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*Aug 27 10:31:12.653: //795129/1DF9C48EB32E/CCAPI/cc_generic_bridge_done:
*Aug 27 10:31:12.653: //795129/1DF9C48EB32E/CCAPI/ccCallDisconnect:
*Aug 27 10:31:12.653: //795129/1DF9C48EB32E/CCAPI/cc_api_get_transfer_info:
*Aug 27 10:31:12.653: //795130/1DF9C48EB32E/CCAPI/ccCallDisconnect:
*Aug 27 10:31:12.653: //795130/1DF9C48EB32E/CCAPI/cc_api_get_transfer_info:
*Aug 27 10:31:12.669: //795130/1DF9C48EB32E/CCAPI/cc_api_get_transfer_info:
*Aug 27 10:31:12.669: //795130/1DF9C48EB32E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x680D99F8, Tag=0x0, Call Id=795130,
*Aug 27 10:31:12.669: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Aug 27 10:31:12.669: :cc_free_feature_vsa freeing 6988D318
*Aug 27 10:31:12.669:  vsacount in free is 5
*Aug 27 16:01:12: %ISDN-6-DISCONNECT: Interface Serial0/1/1:10  disconnected from 9674168877 , call lasted 12 seconds
*Aug 27 10:31:12.721: //795129/1DF9C48EB32E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x69203AAC, Tag=0x0, Call Id=795129,
*Aug 27 10:31:12.721: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Aug 27 10:31:12.721: :cc_free_feature_vsa freeing 6988BD38
*Aug 27 10:31:12.721:  vsacount in free is 4
VIP Super Bronze
DID issue....
Excellent. You need to go back to your provider. You are sending the correct digits to them.
Can you do a "debug isdn q931" for an outbound call. Lets just confirm whats been sent on the isdn leg...I assume you are using ISDN
DID issue....
Ok...
The DID number is - 22139523
Called number - 9830746528
Debug result -
*Aug 27 10:59:14.181: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x810E
    Progress Ind i = 0x8282 - Destination address is non-ISDN
    Progress Ind i = 0x8288 - In-band info or appropriate now available
*Aug 27 16:29:23: %ISDN-6-CONNECT: Interface Serial0/0/0:5 is now connected to 9830746528 N/A - Called number.
*Aug 27 10:59:23.401: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0110
*Aug 27 10:59:24.117: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x810E
    Date/Time i = 0x0C081B102728
        Date (dd-mm-yr)   = 12-08-27
        Time (hr:mnt:sec) = 16:39:40
*Aug 27 16:29:24: %ISDN-6-CONNECT: Interface Serial0/0/0:3 is now connected to 7439142582 N/A
*Aug 27 10:59:24.117: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x010E
*Aug 27 10:59:31.653: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8108
    Cause i = 0x8090 - Normal call clearing
*Aug 27 16:29:31: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0  disconnected from 9831449778 , call lasted 175 seconds
*Aug 27 10:59:31.653: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x825A
*Aug 27 10:59:31.833: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0108
*Aug 27 10:59:31.893: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8108
*Aug 27 10:59:49.253: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x21F5
*Aug 27 16:29:49: %ISDN-6-DISCONNECT: Interface Serial0/1/1:11  disconnected from 9433256354 , call lasted 166 seconds
*Aug 27 10:59:49.257: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x7963
*Aug 27 10:59:49.277: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0xA1F5
*Aug 27 10:59:49.293: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x21F5
*Aug 27 10:59:50.181: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8110
*Aug 27 16:29:50: %ISDN-6-DISCONNECT: Interface Serial0/0/0:5  disconnected from 9830746528 , call lasted 26 seconds
*Aug 27 10:59:50.181: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x8262
*Aug 27 10:59:50.353: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0110
*Aug 27 10:59:50.389: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8110
Please suggest so that I can resolve the issue....
VIP Super Bronze
DID issue....
Pls send the full debug isdn q931. I need to see the call setup. I dont see it in the log you have sent
DID issue....
*Aug 27 10:59:19.665: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x810F
    Date/Time i = 0x0C081B102723
        Time (hr:mnt:sec) = 16:39:35
*Aug 27 16:29:19: %ISDN-6-CONNECT: Interface Serial0/0/0:4 is now connected to 09004246486 N/A
*Aug 27 10:59:19.665: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x010F
*Aug 27 10:59:19.965: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x810D
*Aug 27 16:29:19: %ISDN-6-CONNECT: Interface Serial0/0/0:1 is now connected to 03563252139 N/A
*Aug 27 10:59:19.969: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x010D
*Aug 27 10:59:23.401: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8110
    Date/Time i = 0x0C081B102727
        Time (hr:mnt:sec) = 16:39:39
debug isdn q931 is        ON.
VOICE-GATEWAY#
*Aug 27 11:18:26.705: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8123
    Date/Time i = 0x0C081B103A2A
        Time (hr:mnt:sec) = 16:58:42
*Aug 27 16:48:26: %ISDN-6-CONNECT: Interface Serial0/0/0:5 is now connected to 9231213575 N/A
*Aug 27 11:18:26.705: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0123
*Aug 27 11:19:21.857: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x60D5
*Aug 27 16:49:21: %ISDN-6-DISCONNECT: Interface Serial0/0/0:1  disconnected from 9401688286 , call lasted 788 seconds
*Aug 27 11:19:21.857: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x7967
*Aug 27 11:19:21.881: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0xE0D5
*Aug 27 11:19:22.033: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x60D5
*Aug 27 16:49:28: %ISDN-6-DISCONNECT: Interface Serial0/0/0:6  disconnected from 09905655324 , call lasted 93 seconds
*Aug 27 11:19:28.837: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0122
*Aug 27 11:19:29.313: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8122
*Aug 27 11:19:29.313: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0122
*Aug 27 11:19:31.285: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 3000355
*Aug 27 11:19:31.285: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0124 callID = 0x8276 switch = primary-net5 interface = User
*Aug 27 11:19:31.285: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0124
    Bearer Capability i = 0x8090A3
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0xA98382
        Exclusive, Channel 2
    Calling Party Number i = 0x0081, '3000355'
        Plan:Unknown, Type:Unknown
    Called Party Number i = 0x80, '09693904040'
*Aug 27 11:19:31.381: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x8124
*Aug 27 11:19:31.501: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8124
*Aug 27 11:19:32.737: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x8124
    Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
*Aug 27 11:19:33.161: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8124
*Aug 27 11:19:33.885: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x6173
    Cause i = 0x8290 - Normal call clearing
*Aug 27 16:49:33: %ISDN-6-DISCONNECT: Interface Serial0/0/0:3  disconnected from 3220202817 , call lasted 86 seconds
*Aug 27 11:19:33.889: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x7978
*Aug 27 11:19:33.909: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0xE173
*Aug 27 11:19:34.069: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x6173
*Aug 27 11:19:35.229: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 3000140
*Aug 27 11:19:35.229: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0125 callID = 0x8277 switch = primary-net5 interface = User
*Aug 27 11:19:35.229: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0125
        Standard = CCITT
    Channel ID i = 0xA98384
        Exclusive, Channel 4
    Calling Party Number i = 0x0081, '3000140'
    Called Party Number i = 0x80, '18004250744'
*Aug 27 11:19:35.333: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x8125
*Aug 27 11:19:38.573: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8123
*Aug 27 16:49:38: %ISDN-6-DISCONNECT: Interface Serial0/0/0:5  disconnected from 9231213575 , call lasted 71 seconds
*Aug 27 11:19:38.577: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x8275
*Aug 27 11:19:38.737: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0123
*Aug 27 11:19:38.781: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8123
*Aug 27 11:19:38.921: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x8124
*Aug 27 11:19:40.485: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8125
VIP Super Bronze
DID issue....
The ISDN trace shows that the number you are sending to your provider is not in your DDI range..
ANI=3000355. Is this part of your DDI range? What number is this?
        Standard = CCITT
DID issue....
Ok...
3000355 is my internal number -
Now let me describe you my GW scenario -
There are three PRI in my GW, out of which 2 are used for for Contact center and one for DID.
The port Se0/0/0:15 (Contact Center 1) - 22540470
The port Se0/0/1:15 (Contact Center 2) - 22540471
The port Se0/1/1:15 (Contact Center 2) - 22139500
Now see the config -
interface Serial0/0/0:15
description *** PRI- 22540470 ****
no ip address
encapsulation hdlc
isdn bchan-number-order ascending
no cdp enable
interface Serial0/0/1:15
description *** PRI- 22540471 ****
no ip address
encapsulation hdlc
no cdp enable
description *** DID PRI 22139500 ***
no ip address
encapsulation hdlc
no cdp enable
dial-peer voice 1 pots
preference 1
no digit-strip
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 2 pots
preference 2
no digit-strip
direct-inward-dial
port 0/0/1:15
forward-digits all
dial-peer voice 3 voip
destination-pattern 0...
voice-class codec 1
session target ipv4:192.168.150.1
dial-peer voice 4 voip
preference 1
voice-class codec 1
session target ipv4:192.168.150.2
codec g711ulaw
no vad
preference 3
no digit-strip
direct-inward-dial
port 0/1/1:15
forward-digits all
I have changed the preference and checked but result is the same......
VIP Super Bronze
DID issue....
3000355 is your internal number? 2213... is your DDI. So for inbound calls do you have translation pattern on cucm to change 2213XXXX to 3000XXXX?
If you do then you will need to configure voice xlation rules to change 3000XXXX to 2213XXXX for outbound calls
DID issue....
CUCM Config
Route Group
Route List
Route Pattern
Gateway Config
There is no translation pattern....
DID issue....
But my problem is not for incoming calls.. Incoming calls are doing fine with actual caller ID to a particular DID number.. but when we are making a call from DID number to a cell number , the particular DID number is not showing in the cell phone, instead it is showing the pilot PRI number with preference 1.
Re: DID issue....
s-adhikary
As i wrote to the first post here you have to send the correct digits to the ISP
At that case propably the correct did range is 2213XXXX
So if your extension range is 3000XXXX then the translation rule will be done in Voice Gateway to translate the
Example:
Put the below translation profile into outgoing pots dial peer
translate calling 15
voice translation-rule 15
rule 1 /^3000$/ /2213$/
Put the**  voice translation-profile outgoing OUTGOING ***  (to the pots dial peer for the PSTN network)
Another one issue
you are using 9.! in your route pattern BUT your pots have .T ..You have to strip the 9 if you want to match your destination pattern in the pots dial peer..
You can strip the 9 by going to route pattern( 9.!) and then at the Called Party Transformations choose PREDOT..
cc
Re: DID issue....
We are using 9.! in route pattern and pots have .T and have choosed PREDOT in called party transformation.
DID issue....
While configuring translation pattern in GW router I am getting an error -
VOICE-GATEWAY(config)#voice translation-profile OUTGOING
VOICE-GATEWAY(cfg-translation-profile)#translate calling 15
VOICE-GATEWAY(cfg-translation-profile)#exit
VOICE-GATEWAY(config)#voice translation-rule 15
VOICE-GATEWAY(cfg-translation-rule)#rule 1 /^3000$/ /2213$/
% Invalid input detected at '^' marker.
VIP Super Bronze
DID issue....
I just discovered that thay may not work...
Please let us know how the internal numbers map to the DDI numbers
eg 3000140 ................2213?
300055...............2213?
This is important so we know how to configure the xlation rules
DID issue....
3000002 -----> 22139523
3000004 ------>22139502
3000191 ------>22139503
3000136 ------->22139506
And many more....
VIP Super Bronze
