Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
DID missing in show sip-ua status
Hi, I got two did's missing in show sip-ua status. It happened sudently. They were working and stoped without any changes to the UC. All other dids are registering fine.
I can't find the exact problem but here's the clues I got :
debug ccsip error :
SIP: (476) Attribute mid, level 1 instance 1 not found.
000895: //476/753D6E9180BA/SIP/Error/sipSPI_ipip_update_codec_params_in_channelInfo:
failed to update call entry
000896: //476/753D6E9180BA/SIP/Error/sipSPI_ipip_update_call_entry:
000897: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_set_channel_count: Unable to set CHANNEL_COUNT for callid 476
000898: //476/753D6E9180BA/SIP/Error/sip_iwf_sip_copy_sdp_to_channelInfo: Channel count is not set at this point. Not SIP-SIP or SET_MODE is not done.
000899: //476/753D6E9180BA/SIP/Error/sipSPI_ipip_set_history_info_header: Not SIP2SIP mode
000900: //476/753D6E9180BA/SIP/Error/sipSPI_ipip_set_history_info_header: Not SIP2SIP mode
SIP: (476) Group (a= group line) attribute, level 65535 instance 1 not found.
000901: Jul 30 10:59:36.652: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.2.171:1645,1646 is not responding.
000902: Jul 30 10:59:36.652: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.2.171:1645,1646 is being marked alive.
000903: //478/000000000000/SIP/Error/sipSPIAddPrivacyHeader: Orig Container is NULL...should have value
000904: //478/000000000000/SIP/Error/sipSPIAddAssertedIDHeader: Orig Container is NULL...should have value
000905: //478/000000000000/SIP/Error/sipSPIAddPreferredIDHeader: Orig Container is NULL...should have value
000906: //478/000000000000/SIP/Error/act_sent_OODoptions_wait_response: Out of retries
000907: //-1/xxxxxxxxxxxx/SIP/Error/_send_dns_fail: DNS Query for sip.babytel.ca failed
000908: //478/000000000000/SIP/Error/act_options_wait_dns_resolved: DNS Query failed for query_type:1
000909: Jul 30 10:59:46.156: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.2.171:1645,1646 is not responding.
000910: Jul 30 10:59:46.156: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.2.171:1645,1646 is being marked alive.
000911: //479/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RPCB
000912: //480/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RPCB
000913: //481/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RPCB
000914: //482/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RPCB
000915: //483/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RPCB
000916: //484/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RPCB
000917: //485/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RPCB
000918: Jul 30 11:00:07.776: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.2.171:1645,1646 is not responding.
000919: Jul 30 11:00:07.776: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.2.171:1645,1646 is being marked alive.
000920: //486/000000000000/SIP/Error/sipSPIAddPrivacyHeader: Orig Container is NULL...should have value
000921: //486/000000000000/SIP/Error/sipSPIAddAssertedIDHeader: Orig Container is NULL...should have value
000922: //486/000000000000/SIP/Error/sipSPIAddPreferredIDHeader: Orig Container is NULL...should have value
000923: //486/000000000000/SIP/Error/act_sent_OODoptions_wait_response: Out of retries
000924: //-1/xxxxxxxxxxxx/SIP/Error/_send_dns_fail: DNS Query for sip.babytel.ca failed
000925: //486/000000000000/SIP/Error/act_options_wait_dns_resolved: DNS Query failed for query_type:1
here's my show sip-ua status :
MTL_UC560#show sip-ua register status
Line                             peer       expires(sec) registered P-Associ-URI
1***4062125                      20031      27           yes
1***6685396                      20029      27           yes
1***6278465                      20037      27           yes
1***6671727                      20035      27           yes
1***2274390                      20150      50           yes
1***2274391                      20134      27           yes
1***2274392                      20127      27           yes
1***6642030                      20039      27           yes
MTL_UC560#
There should be two more of there. Which are 1***2274393 and 1***2274396
Any ideas ??
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Anyway if the DID not listed at all, then is not configured to register.
Update IOS and check again.
Thnaks for the quick answer. What is the lastest version ? I got the image
uc500-advipservicesk9-mz.151-4.m4b installed in the UC and in the software pack 8.6.2 the IOS is
uc500-advipservicesk9-mz.151-4.M6 ... are they different versions ??
Ok, I answered myself on this one. I installed the new IOS.
Nothing changed, same results in the show sip-ua register status, same errors in debug ccsip error.
Any other idea ??
Thanks for your help
There is a dns failed message in there.
Anyway, you have to look at debug ccsip message.
Yes I see the dns failed message but it don't really make sense since all the others are registering correctly. Plus, I've tested the dns it is using and it's good. I'll get some ccsip message log and reply with it in a minute
Thanks again
Re: DID missing in show sip-ua status
well, it was resgistering before ... Where do I see if it is still ?? the dial-peers are all configured the same..
lets compage 1***2274390 which is working and 1***2274393 which isn't :
voice translation-rule 4
rule 1 /1***2274393/ /123/
voice translation-rule 18
rule 1 /1***2274390/ /190/
voice translation-profile sp1_Called_4
translate calling 3265
translate called 4
voice translation-profile OD_Called_18
translate called 18
dial-peer voice 3000 voip
description sp1
translation-profile incoming sp1_Called_4
session protocol sipv2
session target sip-server
incoming called-number 1***2274393
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 3014 voip
description OD
translation-profile incoming OD_Called_18
incoming called-number 1***2274390
voice-class codec 1
dtmf-relay rtp-nte
no vad
Thanks !
hummm.. pretty weird, I see messages for all the DIDs with ccsip but not a single one for the missings DIDs, neither sent or received.
Here's a chuck of the traces :
000979: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sip.babytel.ca:5060 SIP/2.0
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKCA1187
To: <>1***2274390@sip.babytel.ca>
Date: Tue, 30 Jul 2013 16:18:30 GMT
Call-ID: 5E0CA750-F86A11E2-8059C465-2D36C2AB
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1375201110
CSeq: 3 REGISTER
Contact: <1>
Expires:  3600
Supported: path
Content-Length: 0
000980: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKCB18FE
To: <>1***2274391@sip.babytel.ca>
Call-ID: 5E0DE039-F86A11E2-805AC465-2D36C2AB
Max-Forwards: 70
CSeq: 3 REGISTER
Contact: <1>
Expires:  3600
Supported: path
Content-Length: 0
000981: //173/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
To: <>1***4062125@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.8516
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKC619D9
Call-ID: 5E0999F0-F86A11E2-8055C465-2D36C2AB
CSeq: 3 REGISTER
Www-Authenticate: Digest realm="sip.babytel.ca",nonce="51f7e882df53649565c7c2fc4f71e1864fd2f75f"
Content-Length: 0
000982: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKCC873
Max-Forwards: 70
CSeq: 4 REGISTER
Contact: <1>
Expires: 3600
Authorization: Digest username="1***2274390",realm="sip.babytel.ca",uri="sip:sip.babytel.ca:5060",response="12e64e8c46154eea835745ac34b0056a",nonce="51f7e882df53649565c7c2fc4f71e1864fd2f75f",algorithm=md5
Content-Length: 0
000983: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKCD1509
To: <>1***2274392@sip.babytel.ca>
Call-ID: 5E0F1889-F86A11E2-805BC465-2D36C2AB
Max-Forwards: 70
CSeq: 3 REGISTER
Contact: <1>
Expires:  3600
Supported: path
Content-Length: 0
000984: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKCE2598
To: <>1***6642030@sip.babytel.ca>
Call-ID: 5E105171-F86A11E2-805CC465-2D36C2AB
Max-Forwards: 70
CSeq: 3 REGISTER
Contact: <1>
Expires:  3600
Supported: path
Content-Length: 0
000985: //174/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>1***6685396@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.8c1d
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKC718E8
Call-ID: 5E0999F0-F86A11E2-8056C465-2D36C2AB
CSeq: 3 REGISTER
Content-Length: 0
000986: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKCF5B4
Max-Forwards: 70
CSeq: 4 REGISTER
Contact: <1>
Expires: 3600
Content-Length: 0
000987: //175/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>1***6278465@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.b5ac
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKC81B3
Call-ID: 5E0A3618-F86A11E2-8057C465-2D36C2AB
CSeq: 3 REGISTER
Content-Length: 0
000988: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKD0F11
Max-Forwards: 70
CSeq: 4 REGISTER
Contact: <1>
Expires: 3600
Content-Length: 0
000989: //176/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>1***6671727@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.92be
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKC91DB8
Call-ID: 5E0AD240-F86A11E2-8058C465-2D36C2AB
CSeq: 3 REGISTER
Content-Length: 0
000990: //177/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>1***2274390@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.cf1d
CSeq: 3 REGISTER
Content-Length: 0
000991: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKD11A58
Max-Forwards: 70
CSeq: 4 REGISTER
Contact: <1>
Expires: 3600
Content-Length: 0
000992: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKD2EB0
Max-Forwards: 70
CSeq: 4 REGISTER
Contact: <1>
Expires: 3600
Content-Length: 0
000993: //178/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>1***2274391@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.0755
CSeq: 3 REGISTER
Content-Length: 0
000994: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKD325B1
Max-Forwards: 70
CSeq: 4 REGISTER
Contact: <1>
Expires: 3600
Content-Length: 0
000995: //179/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>1***2274392@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.0267
CSeq: 3 REGISTER
Content-Length: 0
000996: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKD4CE1
Max-Forwards: 70
CSeq: 4 REGISTER
Contact: <1>
Expires: 3600
Content-Length: 0
000997: //180/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>1***6642030@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.cc8f
CSeq: 3 REGISTER
Content-Length: 0
000998: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP ***.231.97.100:5060;branch=z9hG4bKD5130C
Max-Forwards: 70
CSeq: 4 REGISTER
Contact: <1>
Expires: 3600
Content-Length: 0
000999: //173/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <>1***4062125@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.1bcc
CSeq: 4 REGISTER
Contact: <1>;expires=40
Content-Length: 0
001000: //174/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <>1***6685396@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.7e9c
CSeq: 4 REGISTER
Content-Length: 0
001001: //175/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <>1***6278465@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.e001
CSeq: 4 REGISTER
Content-Length: 0
001002: //177/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <>1***2274390@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.ba23
CSeq: 4 REGISTER
Content-Length: 0
001003: //176/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <>1***6671727@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.ec28
CSeq: 4 REGISTER
Content-Length: 0
001004: //178/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <>1***2274391@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.815c
CSeq: 4 REGISTER
Content-Length: 0
001005: //179/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <>1***2274392@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.a578
CSeq: 4 REGISTER
Content-Length: 0
001006: //180/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <>1***6642030@sip.babytel.ca>;tag=7c5c51991a86f982b0b6379bb22f7b1a.1c97
CSeq: 4 REGISTER
Content-Length: 0
Ok got it. The problems was two things actually..
in the ephone-dn for ext 123, the number parametter had no reg both instead of no reg primary
for the other one, which was only a dial peer to an analog port, there was a no sip-register command.
What is still weird is that it was working, no changes has been made then it stopped working suddently but, now it's all good so I guess I won't ask myself too much question since those UC seems to change their configurations by themselves anyway.
Thanks again for you help, case closed
461
