Community Member
DID on CCME
Hi Guys,
What is the best practice for DID on a CCME?
I have 3 banks of DID numbers
587-3616 to 3620
587-3629 to 3633
718-5678 to 5682
CO is sending 7 digits, and customer site has 3 digits extension
I was thinking of this…
voice translation-rule 1
rule 1 /5873616 / /616/
rule 5 /5873620/ /620/
rule 6 /5873629/ /629/
rule 10 /5873633/ /633/
rule 11 /7185678/ /678/
rule 15 /7185682/ /682/
Please recommend any better suggestions? Any help would be greatly appreciated!
3 ACCEPTED SOLUTIONS
Bronze
Re: DID on CCME
Are you planing to do a translation rule per ephone-dn?
You can prob. combine them all to two rules, since calls which are not in your did ranges should not be routed to you from the pstn.
Rules can be:
rule 1 /58736/ /6/
rule 2 /71856/ /6/
Also, outbound translation has to be configured, for the calling number.
HTH, Avner.
Bronze
Re: DID on CCME
r u planing to use cue? analog phones?
dialplan-pattern is only applied to ephone-dn's, which might cause issues when you have the above mentioned devices.
regards, Avner.
Hall of Fame Super Gold
Re: DID on CCME
No analog phones or CUE. I think you will find that is easy to reproduce the problem, but I didn't bothered to raise a a case with TAC, because I'm happier using translation-profile anyway.
Bronze
Re: DID on CCME
Rules can be:
rule 1 /58736/ /6/
rule 2 /71856/ /6/
HTH, Avner.
Community Member
Re: DID on CCME
What I did was, under telephony-service
dialplan-pattern 1 5873... extension-length 3
dialplan-pattern 3 7185... extension-length 3
And it seems good. I am not sure if this is a good practice.
Re: DID on CCME
Good practice and even better if it works for you. Last time I tried, the second dialplan-patter did not worked. I have to say, it was a different situations, two same DID ranges and and two E1 PRI circuits.
Bronze
Re: DID on CCME
regards, Avner.
Re: DID on CCME
Community Member
Re: DID on CCME
It's a 1 - T1 PRI circuit line, and only for ephone-dn's.
I am using cue, and VM seems to function fine, along with the AA, and transfer to VM.
However I do have 1 DID that is for the Fax. What I did was created...
voice-port 0/1/0
description FXS
dial-peer voice 502 pots
destination-pattern 5873620
port 0/1/1
So far I have tested, and the PRI does ring the FXS port, along with the proper DID's with the correct extention and phone.
I have been reading the translation profile and it seems slick. I might have to tried that too.
Re: DID on CCME
when connecting fax, I'm usually happy doing like you did (no pun intended :), that is leaving the full number as destination-pattern.
This because is seldom necessary to assign to fax a real extension to be called from within the office.
Thanks for the nice rating and good luck!
213
