DID with PRI
Dear sir
I have PRI number 5205521. and DID are map on my PRI number .I m using H.323 ,i can easily call to PSTN , but when i tried to call on my internal IP phone call get disconnected automatically.
PRI number is 5205521.
DID numbers are 52087XX
My IP phones number are 8701 ,8702 etc.
i am unable to call on my IP phones.
I am attaching my Runing configuration , and debug out put, plz help me out.
I m using four number internal dial plan.
I have also tried with
voice translation-rule 1
rule 1 /2152087../ /87../
I have attached Running-config and debug .
thanks
1 ACCEPTED SOLUTION
Silver
Re: DID with PRI
What resolved it? Don't leave us hanging! lol
Hall of Fame Super Gold
Re: DID with PRI
Hi, I think translation rule should be:
rule 1 /^21520/ //
Haven't checked your config beside that.
Re: DID with PRI
kindly check config. as i have tired rule 1/^21520/ // also.
Re: DID with PRI
Seems fine. Check with "debug isdn q931" and "term mon" which number are you receiving. The you can also check with "debug ccapi" what happens with the call.
Re: DID with PRI
-deleted-
Re: DID with PRI
how many digits is the telco sending to you?
many of them already send the last 4 digits so you don't need to apply any translation rules
a debug would tell you that
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Re: DID with PRI
thanks its resolve.
Silver
Re: DID with PRI
Re: DID with PRI
:-) actually Telco was not sending the 4 digits ;-)
134
