Community Member
Difference between DS0-group or TDM-group?
Hi, does anyone know when one would use the DSO-group vs. the TDM-group commands? I understand they would both be used with voice but don't understand the difference.
Thanks!
Thanks, Lisa G
1 REPLY
Hall of Fame Super Gold
Re: Difference between DS0-group or TDM-group?
ds0 groups is to terminate voice on CAS T1. Application is voice gateway.
tdm-group does timeslot multiplexing, and will send the timeslots unchanged to a destination also specified in configuration. Application is T1 or E1 add-drop multiplexer (and more).
237
