Difference between UCOS restricted version and unrestricted version
Hi to all,
somebody knows which is the difference between restricted version and unrestricted version??
Which are the main differences??
David
1 ACCEPTED SOLUTION
Hi.Basically restricted
Hi.
Basically restricted version has encryption enabled and unrestricted not.
You may give a look to this thread.
https://supportforums.cisco.com/discussion/11409366/restricted-version-and-unrestricted-version-ccm-comparison
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi.
Carlo
Thanks for your quick answer!
Thanks for your quick answer!!!
Regards.
David
52
