Difference configure MeetMe with SW or HW CFB
I am running MeetMe on CUCM 8.03 with no issue and getting request more MeetMe number.
I wonder if it would be impact performance issue on CUCM server?
If I configure DSP on gateway for MeetMe, isn't there any more benefits rather than SW?
Your advice would be appreciated.
1 REPLY
The CUCM config is the same, whether you use a SW or HW CFB depends on the MRGL.
You can create as many meet-me DNs as you want, the SW CFB can only handle 128 streams.
You define the maximum amount of participants via service parameters.
There is really never more impact on CUCM than what is already expected with those 128 stream.
The benefit of HW CFB is more codecs can be used for meet-me, the drawback is less users can join.
Only if you configure a only G711 (32 users) or only G729 (16 users) you can get more than the regular 8 users.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
344
