Community Member
Difference
Hi All,
What exactly is the difference between CTI ports & CTI Route points?
regds,
aman
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Difference
Aman,
Think about a IPCC solution, people dial the cti route point to access an application, cti port is what answers the call and provides treamtment, basically a virtual phone that connects to the calling device (IP session between the 2).
HTH,
Chris
Re: Difference
hi there
The CTI port is actually a virtual device that allows you to create a virtual line
while with CTI route point u can use it as virtual phone to forward calls to send to voice mail, CRM and so on ..
if helpful Rate
Re: Difference
Aman,
HTH,
Chris
Community Member
Re: Difference
thanks for info
Community Member
Re: Difference
Hello Chris,
I ran across your post as I wanted to pose the same question. So if I have a remote user, who does not use IPC or even our Unity vmail, and we simply forward her company number to her home phone -- the cti port is the fitting solution here? Thanks in advance, Kelly.
Re: Difference
a CTI RP with CFA to the external number or a translation pattern work on that scenario
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Re: Difference
I appreciate your reply. Could I bother you to go into why choose the route point over just creating the cti port/phone and CFA to external as well. I'm still not sure as to why use one over the other. -Kelly
Re: Difference
CTI ports are for 1st hand control, meaning they will take calls for another app, CUE, UCCX, UCCE, ETC.
CTI route points are merely routing as the name implies
java
java
225
