Differences between CUCM 6x & CUCM 7x
I have a query - is there any significant difference between CUCM 6x & CUCM 7x from a memory viewpoint ?
1 ACCEPTED SOLUTION
Re: Differences between CUCM 6x & CUCM 7x
Not really, the memory handling is still on Linux control, so it will try to grab as much memory as possible
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Thank you very much.
Ashok.
233
