different dial-peer for different calling numbers
I have a dial-peer with "destination-pattern like 00033T"
to redirect these call via voip to another CCME in Frans.
But, it same that with ATA + analog fax, I have a problem, sending not possible.
To find a working workaround, I would to use this dial-peer only for the phones.
And define another dial-peer for the ATA+Fax.
But how is it possible to find the good dial-peer for that ?
Is it possible to say that for calling number xxx and yyy, use dial-peer 1, else, dial-peer 2 ?
Thx
Re: different dial-peer for different calling numbers
You can try it using cor ("class of restriction") one of the dial peer would be in a cro class reachable by the ata and another in a cor class reachable by the ip phones.
Hall of Fame Super Gold
I did not understood your problem too well, but if you need to do routing based on calling number, yes it's possible. See:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
Note that is the ATA is in SCCP mode, you will need to configure the translation-rule at ephone-dn level.
Please remember to rate all useful posts using the scrollbox below!
thx all
The response with cor is exactly what I asked.
But at lunch time :), I find the solution myself, it's similary to the solution of p.bevilacqua
... and in my case, the only thing to do that is cha nging a 0 to 9 ... all other thing are implimented in the past ...
Fur the future : More lunch time => more work
111
