Different MCS Platform in the same UCM cluster?
I wanted to understand if I can have a UCM cluster with different MCS platforms.
For example MCS 7845 as a Publisher and MCS 7835 & MCS 7825 as a Subscriber.
I feel that technically this should be possible apart from considering the fallback capacity in case of the MCS failure. However I am interested to know if this is technically a feasible option or not.
Has anyone seen or done any such deployments.
Any inputs would be appreciable.
-> Sushil
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Different MCS Platform in the same UCM cluster?
Hi Sishil,
Hope all is well :) There is no requirement that all MCS Servers in a cluster be the exact same models. So, your example would work just fine as long, as you correctly noted, that "Failover" numbers are considered and factored into the equation.
Our MCS boxes are all the same right now but our past deployment had some differences that never caused any issues.
Hope this helps!
Rob
Hi Sishil,
Hope this helps!
Rob
Excellent Rob. Thanks a lot.
-> Sushil
Hi Sushil,
You are most welcome my friend! Sorry for the delay in getting back to you :)
Take care,
Rob
No problems Rob.I guess your reply was quick for me :)
-> Sushil
211
