Community Member
Different MOH per phone
Hey all,
We are a muli site house and are currently doing MOH at the gateway verse streaming the MOH over the network.
We now have a need to have two files play on a single router.  Is this possible?  We have a seperate router at the location which is able to steam the other file...  but my question is how do i join the different streams?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Yes, recent IOS (do not recall exact version) introduced the ability to specify up to 5 different MOH sources.  the way you allocate them is by DN ranges.
HTH,
Chris
Community Member
i fail at google and hate to ask this of you...
are you able to link any command references?
217
