Community Member
different ring for external incoming call and internal incoming call + CME
Hi all,
I m using a CME 8.8 , and i want know  if there is a possibility to have a different ring according the type of call :
Example :  we have a following DN 1000,  the customer want to a have a different ring according to :
1- External incoming call  to 1000
2- Internal incoming call to 1000
Thanks for help
Hicham
Community Member
As far as I know this is not possible on same line.
You can although create 2 different extensions on separate line buttons on the Phone and change the ringtone from the IP phone for each line button if IP phone has 2 buttons minimum.
Super Bronze
You already have a 'different' ring of sorts by default - internal calls should ring once (i.e. 'ring', whereas  external do a double-ring (i.e. 'ring ring').
It's seomthing you don't notice until it's been pointed out, but then it seems pretty obvious!
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
314
