Different ring tones for external and internal calls
Hi all,
Any idea to set up different ring tones for external and internal calls?
environment:  CUCM9+ CUBE SIP trunking
8961 phone
I tried with the following configuration, it looks it doesn't make any difference.
https://supportforums.cisco.com/discussion/11484786/different-ring-tones-external-and-internal-calls
Your help and information are appreciated.
Master01
1 REPLY
All you can change is the
All you can change is the cadence of the tone, this has been discussed plenty of times, before at CSC.
You cannot have a whole different ringtone for internal Vs. External calls, same ringtone, slightly difference cadence.
java
if this helps, please rate
www.cisco.com/go/pdi
146
