Community Member
different rings for Incoming calls
I have CCM6.0 and Cisco IP phones 7941 and 7961. Can I have different rings for incoming calls? Like I want a call coming for a certain extension to ring differently than others?
Re: different rings for Incoming calls
the only option is a slight different cadence on the tone.
not like having 2 completely different ring tones if that's what you were looking for
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
thanks. I would like to be able to have a different ring (when my boss calls) than other incoming calls.
Not sure if that possible
not possible, as i mentioned the only option is a slight different cadence for internal/external.
there is no per user ringtone capability
java
java
159
