different SIP accounts per line / voice dn on outgoing calls
I'm looking for a solution to use my different SIP accounts for the different line configurations (dn 1 and dn 2) on the 9971.
With dn 1 the system should use voice translation-rule 3 (phone number 06209123456) where for dn 2 the system should use translation-rule 4 (phone number 05209789012) for all outbound calls.
So far the system is always using the dial-peer voice 1 voip (where translation profile OUT is assigned). Even removing the translation profile assignment in dial-peer voice 1 voip doesn't help.
Configuration is attached.
Any ideas?
Regards, Frank
Everyone's tags (3)
Check this:
Support for Multiple Registrars on SIP Trunks on a Cisco Unified Border  Element, on Cisco IOS SIP TDM Gateways, and on Cisco Unified  Communications Manager Express
http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb_9655_ps5640_TSD_Products_Configuration_Guide_Chapter.html
Configuring Multiple Registrars on SIP Trunks
http://www.cisco.com/en/US/docs/ios/voice/sip/configuration/guide/sip_cg-multi-registrars.html
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
first of all, what you are seeing is expected behaviour, all outbound traffic will be hitting:
dial-peer voice 2 voip
description **Incoming VOIP Call**
translation-profile incoming IN
session protocol sipv2
session target ipv4:10.10.10.1
incoming called-number .%
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
This is because your incoming called number .% is a catch all for all inbound dial peers. including a call originated from your 9971. I would do the following (please note that this is only a concept, I havent been able to test it).
incoming called-number 06209123456
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3 voip
incoming called-number  05209789012
voice-class codec 1
dtmf-relay rtp-nte
no vad
these two dialpeers are now PSTN inbound.
create 2 more dial peers:
dial-peer voice 20 voip
translation-profile incoming IN 8x
answer-address   06209123456
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 21 voip
translation-profile incoming IN   9x
answer-address  05209789012
voice-class codec 1
dtmf-relay rtp-nte
no vad
now create the two translation profile 9x and 8x, and these are just examples, all they need to do is add either an 8 or a 9 in front of any dialed number,
now you will need to create two outbound dial peers, one for SIP provider A  (with the 9x destination pattern) and one for provider B (with the 8x destination pattern) and dont forget to strip of the 9 and the 8 respectively.
not really a s3xi solution, but it will work
Please remember to rate useful posts, by clicking on the stars below.
227
