Different Voice Bundles
Our Reseller quoted us Cisco 2901 Voice Bundle with CUBE-10 Licesne. Will it support CME? or I should go for CME-SRST License? I dont need CUBE feature, so even if it support CME , Am I paying more in the name CUBE license?
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
CME licenses are Right to Use (RTU) which means there are honor based, so technically you can still configure it, however legally you are not entitled to CME without CME licenses.  You can always add those on via separate purchase.
HTH,
Chris
Silver
Just to add for already present answers - Cisco by default included CUBE licenses in recent voice bundles. So for same price you are already given some CUBE RTU licenses which is good because of obvious SIP popularity these days and in the future.
HTH,
Dragan
HTH, Dragan
If you need CME then you should be getting the CME bundle with CME/SRST licenses.  If you do not require CUBE licenses there is no reason to get them.
HTH,
Chris
Thanks Mr. Chris,
In description it mention only CUBE licnese. Is it mean I will not be able to configure CME in that router??
HTH,
Chris
Thank You
Silver
HTH,
Dragan
HTH, Dragan
96
