tka
Different ways to change the Caller ID in CCM6.X
Hi ,
I'm using Extension mobility. What are the different ways to change the Caller ID , that appears in the called person phone screen? Is there only the Caller ID field in the Line config ?
regards,
1 REPLY
Re: Different ways to change the Caller ID in CCM6.X
yes, EM is no different from a regular phone in the basic config. same fields, same usage
java
if this helps, please rate
java
www.cisco.com/go/pdi
142
