Community Member
digit manipulation CCM 6.1.1
hello
On a CCM 6.1.1 I wish during a call outside to another site that the number called is modify (removal of the first digit) before call routing (internal)
Ex: 0 01 46 98 45 70
moved 0 01 46 98
routing internal 4570
but on "translation patern" the dial is blocked...
1 REPLY
Re: digit manipulation CCM 6.1.1
make sure the translation pattern can reach the route pattern you want to use.
you can also modify the called and calling in the route pattern
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
128
