Community Member
digit manipulation help
Hi all can someone help me out with digit manipulation
i have 5 extensions numbers  that al start with 7XXXX ( al different numbers )
What i would like to realize is that when one of those extensions make calls out the number presentation wil change .
So the called number sees a different number.for a example last five digits 77777 ( this is a hunt pilot)
When for example caller B calls back to this number 77777 they can reach one of those 5 numbers.
What is the best way to do this?
1 REPLY
This topic has been discussed
This topic has been discussed hundreds of times, a search on CSC will provide the options for this
https://supportforums.cisco.com/comment/9847321#comment-9847321
java
if this helps, please rate
www.cisco.com/go/pdi
28
