Community Member
Digit Translation, Why doesn't this work?
I see on several sites a simple digit translation command and they say it works but when I enter it into my 2610XM (CME 4.0.1.0) amd my 2851 (CME 8.6), they both get me the error below.
Command:
     LAB_2610XM(cfg-translation-rule)#rule 1 /2535551.../ /4.../
Error
% Invalid input detected at '^' marker.
If I remove the wildcard it works fine.  But if an 11 digit number I get a 5 digit result.  Am I doing something worng or arre the websites wrong? Or, is this command for CUCM only?
If I enter the command:
rule 1   /2535551.../  /7/
it works but my results are:
Original number: 2535551000     Translated number: 7
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
As you can see, my last three digits do not come over in the translation
2 ACCEPTED SOLUTIONS
Re:Digit Translation, Why doesn't this work?
Please visit the link below for more information on translation rules.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmedialp.html
HTH Regards, Yosh
VIP Red
(Without testing) I believe it should be (using number slicing):
rule 1 /^253551\(...\)/ /4\1/
Please remember to rate useful posts, by clicking on the stars below.
HTH Regards, Yosh
VIP Red
Community Member
That did it.  lots of web sites got that one wrong but here it is right!
Thank You!!!
VIP Red
Thx Michael,
just remember, this is where the top dogs live
208
