Digit translation working weird
Here is my rule:
     LAB_2610XM(config)#voice translation-rule 40
     LAB_2610XM(cfg-translation-rule)#rule 1 /[25-79]000/ /3000/
Here are my results:
LAB_2610XM(cfg-translation-rule)#do test voice translation-rule 40 8012000111
Matched with rule 1
Original number: 8012000111     Translated number: 8013000111
Original number type: none     Translated number type: none
Original number plan: none     Translated number plan: none
This time we tested a ten digit number and again we get the expected results.
LAB_2610XM(cfg-translation-rule)#do test voice translation-rule 40 3525000555
Matched with rule 1
Original number: 3525000555     Translated number: 3300000555
Take a good look at this example. Yes It does match our criteria with the 5000 in the number 3525000555 but look what the translated to number is; 3300000555. Here is one of those unexpected results you must watch out for and is why we test our configurations. CME found a matching number because of the 5000 in the string and when it replaced it with 3000 as our expression states, it placed the 3000 at the first 5 in the string.
I am trying to write a CCNA Voice lab manual and am worndering why the last example did what it did and what can I do to get it to give a result of 3523000555.
1 ACCEPTED SOLUTION
Silver
Works fine for me on 12.4(24)T2:
Router#test voice translation-rule 40 3525000555
Matched with rule 1
Original number: 3525000555     Translated number: 3523000555
What IOS version are you running?  May be a bug.
Try running the test while also running "debug voice translation" and attach the debug as well.
Silver
Matched with rule 1
I am using c2600-ipvoicek9-mz.124-15.t7.bin.  There must be a bug in my version.  I have also tested version 15.1 and it works fine.  I found a bug in my version then.   Thank you for you help.
146
