Dir Sync
All,
I'm having problems synchronizing with Open LDAP users. Actually I can sync a maximum of 250 users.
Is there any configuration or limitation that causes this?
Thank you!
Luciane de Medeiros
  • IP Telephony
Everyone's tags (1)
Dir Sync
No, either that's because it's only finding 250 "valid" users to sync with, the OU you're pointing only has those users, or the user you used for LDAP only has permissions to read over those users. Other than that, it might be another problem and you need to read the dirsync logs to find more info.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Dir Sync
Hello, Java.
The client's LDAP was limiting the number of visits to 250.
Thank you!
Luciane de Medeiros
238
