Direct all calls to Music On Hold
I have a customer who wants to divert all calls directed to an attendant console pilot to divert to a Music On Hold audio service in CallManager 4.1. Thay have uploaded a file with a holiday greeting and thi needs to be played to all incoming calls.
1 ACCEPTED SOLUTION
Re: Direct all calls to Music On Hold
You would need to send them to a pilot point with broadcast and queuing.
That's the only method for someone to call and go to MOH directly.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Silver
As an alternative, if they have Unity - they could have all incoming calls go to a call handler, play the holiday greeting as the CH greeting and then in the after greeting action be transferred to the AC.
HTH,
Art
263
