Direct connection between IP Phones and Teleco?
While examining my new 7941 IP Phone, I noticed that there is a lable that mentioned that 79xx can be connected to Telco?
Is this right to connect the ip phone directly to PSTN ?!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks a lot.
1 REPLY
Re: Direct connection between IP Phones and Teleco?
If you mean can you connect the phone directly to a POTS line then the
answer is no. I am guessing that if you are looking at a port it would be
the "Aux" port. This port is meant to be used for connecting an expansion
module. Of course the 7941 does support the expansion module but that is
probably a manufacturing thing.
HTH.
Bill
Please remember to rate helpful posts.
On 9/4/10 10:21 AM, "AhmedBassiony"
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
141
