Direct-Inward-Dial setup
I have a New T1 im trying to set up for Direct-Inward-Dial and I can not get this working. I can make outbound calls but not receve any incoming. I have verfiyed that there is a translation pattern and it exists. I have a new Partion and CSS for this as well. I am expection 10 digits coming from the PSTN and sending out 4 to the PSTN. Any thoughts?
My gateway is an H323 running catos if that helps
Hall of Fame Super Silver
Re: Direct-Inward-Dial setup
Please post your router config.
Is this a PRI? If so post output of "debug isdn q931"
Chris
Chris,
This router is runnig CATOS and it is an mgcp gateway not a H323 as I had stated here is the shrun of the mod/port as well we are using mod 4 port 2
#module 4 : 8-port T1
set port voice interface 4/1 dhcp disable 172.20.23.221 255.255.254.0 vlan 22 tftp 172.20.18.2 gateway 172.20.23.254
set port voice interface 4/2 dhcp disable 172.20.23.222 255.255.254.0 vlan 22 tftp 172.20.18.2 gateway 172.20.23.254
set port voice interface 4/3 dhcp disable 172.20.23.223 255.255.254.0 vlan 22 tftp 172.20.18.2 gateway 172.20.23.254
set port voice interface 4/4 dhcp disable 172.20.23.224 255.255.254.0 vlan 22 tftp 172.20.18.2 gateway 172.20.23.254
set port voice interface 4/5 dhcp disable 172.20.23.225 255.255.254.0 vlan 22 tftp 172.20.18.2 gateway 172.20.23.254
set port voice interface 4/6 dhcp disable 172.20.23.226 255.255.254.0 vlan 22 tftp 172.20.18.2 gateway 172.20.23.254
set port voice interface 4/7 dhcp disable 172.20.23.227 255.255.254.0 vlan 22 tftp 172.20.18.2 gateway 172.20.23.254
set port disable 4/8
set port name 4/3 Verizon
set port name 4/4 Verizon
set port name 4/5 Verizon
set port name 4/6 AT&T
set port name 4/7 AT&T
Bronze
Assume if you have 4 digits for your extension.
Can you confirm that under Gateway at CCM web admin page. Please you select 4 at Significant Digits. And make sure the Calling Serach Space has patition that use at Phone Line?
Ken
424
