direct-inward-dial & sip trunk
nmdc.kzstan
How can I forward incoming call from sip server to cme to one of the internal numbers?
In fxo and e1 channel DID can be configured and there's no such command under "dial-peer voice voip"
dial-peer voice 1 voip
translation-profile incoming SIP_IN
session protocol sipv2
session target sip-server
session transport udp
incoming called-number XXXXXXX
voice-class codec 1
dtmf-relay rtp-nte
no vad
TIA
5 Replies 5
Chris Deren
So, is your desire to configure PLAR type of config where are calls get routed to the same destination?
Or simply route calls according to received DNIS digits?
Chris
Hi Chris,
I wanted to route calls according to DNIS. The above config worked with the right translation-profile, now I understand
that no DID is needed for SIP incoming call.
Thank you.
are you using CME or CUCM?
Leonardo Santana
*** Rate All Helpful Responses***
All you need to do is simply create matching dial peers with destination-pattern, if this is all on CME as long as the called numbers match the extension you should not need anything, if you need to translate digits then you have couple of options:
use translation rules
apply  dialplan-pattern to telephony-service configuration.
Chris
With CME if i did want to configure a PLAR type of config on an incoming SIP trunk where are calls get routed to the same destination what would i need to to?
