06-18-2010 11:37 PM - edited 03-15-2019 11:18 PM
I have UCM 6.0 and voice gateway 2811 registered to the UCM using H.323.
How to configure a direct line (Incoming/outgoing) using FXO?
-- for incoming no problem I configured a connection plar opx under the voice port
-- for outgoing I have a way to add a prefix before all outgoing calls of the direct line line (*9) and all the other staff make outside calls using (9).
-- the problem i have a lot of employees need a direct line and everytime i should creat route patterns for each, so i have a lot of route patterns
-- i need a way to configure the direct line for outgoing on the voice gateway 2811 based on the calling number ( extension) for example:
Extension 5400 is calling 45366665 and should go through voice-port 0/0/0 ( which is direct line for 5400). is there a way on the voice gateway to take the calls through voice port 0/0/0 based on the extension number 5400 ???
Solved! Go to Solution.
06-19-2010 12:53 AM
in order to bind a specific extension to a specific FXO port you need to do the following:
voice translation-rule 1
rule 1 /^/ /19/
note: "19" can be any number which you will reference later in the dial peer
voice translation-profile Test
translate called 1
voice-port 0/0/0
connection plar opx 5400
description direct line 45366665
caller-id enable
dial-peer voice 200 voip
translation-profile incoming Test
answer-address 5400
dial-peer voice 19 pots
destination-pattern 19T
port 0/0/0
you have to create the above for every direct line.
i hope this will work with you. For me i tested and it is working good.
regards,
Ibrahim Chehouri
06-19-2010 12:53 AM
rule 1 /^/ /19/
translate called 1
voice-port 0/0/0
caller-id enable
answer-address 5400
port 0/0/0
regards,
Ibrahim Chehouri
06-19-2010 02:38 AM
Great it's working fine but i change only the translation- rule from /^/ to /^9/ because the calls come with 9 from the call manager
06-20-2010 01:35 AM
thats great
