Community Member
direct line reservation in CUCM
Dear all, we have to reserve some direct PSTN lines for manger.
the platform is CUCM with 2911 as the gateway.
in CUCME its quite simple and i have deployed it a couple of times using COR but for CUCM i have no idea.
any suggestions !
I'm not sure what you want to do by reserving the line, if you are looking to restrict access like a class or restriction (COR) list, calling search spaces (CSS) and partitions are the same idea.  The only difference is that a number is placed into a partition (group) and the css needs to have that group in it's list to allow access.
CUCM cannot reserve DS0s for anyone, there's no method for doing such thing.
MLPP would be your best option for doing this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
147
