Directing 1 PSTN to a specific extension and use for incoming and outgoing
any one can help configure a specific pstn line to a specific extension
call manager 6 with voice gateways
voice gateways as 12 pstn lines,
but i need a specific line to be direct to a specific extension so the user can exclusivily use it for him only for making outgoing and incoming
Hall of Fame Super Gold
This is done with CSS/Partitions and associating gateway resources.
Are you familiar/certified for CUCM configuratio? If not it would be better have someone that is, to do it.
Hall of Fame Super Silver
What type of lines?
Are you using MGCP, SIP or H323 to control the GW?
Chris
Lines are FXO PSTN
H323
Then configure the voice-ports with PLAR configuration pointing to the actual extension and ensure it matches a voip dial-peer that points to CUCM, i.e.
voice-port 3/0
connection plar opx 2000
caller-id enable
dial-peer voice 1 voip
session target ipv4:
destination-pattern 2..
dtmf-relay h245-signal
codec g711ulaw
no vad
HTH,
Chris
hi chris,
will it work for outgoing call through specific port if the extension for the user is 2241 and fxo port is 0/0/1, and outgoing should work only for the user 2241 only
voice translation-rule 9
rule 1 /\(5.......\)/ /90\1/
rule 2 /^1\(......\)/ /9\1/
rule 3 /\(3.......\)/ /90\1/
rule 4 /\(4.......\)/ /90\1/
rule 6 /\(6.......\)/ /90\1/
rule 7 /\(7.......\)/ /90\1/
rule 8 /\(2.......\)/ /90\1/
voice translation-profile incoming_add_9
translate calling 9
voice-port 0/0/0
translation-profile incoming incoming_add_9
supervisory disconnect dualtone mid-call
supervisory custom-cptone SA-custom
no battery-reversal
cptone BR
timeouts call-disconnect 2
timeouts wait-release 2
connection plar opx 5555
caller-id enable
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
voice-port 0/0/1
no battery-reversal
cptone BR
caller-id enable
dial-peer voice 1000 voip
preference 1
destination-pattern 1...
session target ipv4:10.22.22.241
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 1001 voip
preference 2
session target ipv4:10.22.22.240
codec g711ulaw
no vad
dial-peer voice 100 pots
destination-pattern 9T
port 0/0/0
dial-peer voice 101 pots
port 0/0/1
translate calling 9
voice-port 0/0/0
no battery-reversal
cptone BR
caller-id enable
voice-port 0/0/1
no battery-reversal
cptone BR
caller-id enable
preference 1
codec g711ulaw
no vad
preference 2
codec g711ulaw
no vad
port 0/0/0
port 0/0/1
254
