Directories contacts
Dear Team
We have two call managers in London and Dubai. Both are integrated with the LDAP on their sites. How we can look London directories contacts in the Dubai phones?
xml file is need to add in Dubai CUCM?
Have you tried making a new phone service that points to the others sites directory URL. I don't know if you can kjust point to their corporate directory itself but its something.
Yosh
HTH Regards, Yosh
Is there connectivity between the sites???
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia yes, connectivity are there between the sites. Please advise how to achieve this task .
Other than trying Yosh's suggestion, you would need to create custom directories for this.
java
java
134
