Directories
pcromwell
Level 3
Level 3
We have an AD integration with CUCM 7.0 for our cluster. We would also like to have
the directory of a seperate office which is on a different cluster.
Are there any methods available to do this and if so which is best?
I was wondering about connecting to their AD as well if this is poaaible although I dont' think they would allow us
Jaime Valencia
it is possible but that would require creating a custom directory script in order to search both directories, either both in same option or configure 2 separate options
java
if this helps, please rate
java
sorry to ask the obvious, are there any documents or references where I could write
a script
