Directory information
I am trying to add users to the Directory but I keep getting error messages such as
Active Server Pages error 'ASP 0115'
Unexpected error
/CCMAdmin/usersidebar.asp
A trappable error (E06D7363) occurred in an external object. The script cannot continue running.
has anyone experienced this before
1 REPLY
Re: Directory information
1. Identify the correct directory administrator password. Let it be .
2. Open command prompt. Run PasswordUtils . This will generate encrypted
password. Let it be
3. Set the value of DCDMGRPW and MGRPW in registry, "under
HKML\Software\Cisco Systems, Inc.\Directory Configuration", to
4. Open C:\dcdsrvr\directoryconfiguration.ini. Set the value of passwd to
5. Open command prompt. go to C:\
6. Run the command UMEncryptText . This will generate out.txt in the same
folder from which it was run, i.e C:\
7. Open out.txt and copy the contents after "Text=". This long hex value is the encrypted
8. Open C:\dcdsrvr\config\UMDirectoryConfiguration.ini using "notepad"
(Please do not use any other text editor).
9. Set the value of CiscoLdapPwd and UserLdappwd to .
10. Save the file and exit.
11. Restart IISAdmin service and try accessing the CCMAdmin user pages.
93
