Directory LDAP: Only FirstName
iantra123
Level 3
Level 3
We're using CUCM 8.6, and a MsActiveDirectory as LDAP Directory.
In the system,there are person that have not Last Name but just FirstName only.
When we make searh in the corporate directory, these person (that have firstname only) are not seen.
Is there any way to tell the CUCM to show directory information even if there are only the FirstName in the Active directory?
Antra
Leonardo Santana
They are not sync with cucm you will need To fill the last name field on AD.
See this doc:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/directry.html
Rate this If helps you
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Leonardo Santana
See this doc:
Leonardo Santana
Leonardo Santana
