Directory Lookup
I am using cm version 7 with AD integration.
Is there a way for a user to search the corporate directory on more than just FN, LN and Number,alot of users want department or groups etc
also is there a way to perform name lookups on inboud calls?
1 REPLY
Red
Re: Directory Lookup
To customized the directory lookup, you'll have to build your own XML and host it on a HTTP server.  Then you go to CUCM > System > Enterprise Parameter.  Change "URL Driectory" to point to your XML.
I'm not a developer thus I can't provide more detailed instructions.  You may take a look at the documents at http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_reference_guides_list.html.  Or subscribe to Cisco's "developer support" service.
Michael
http://htluo.blogspot.com
139
