Directory number associations
Dears
In the end user page in Directory number Associations i am not getting any IPCC extension options why???
 is it this is normal.
thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
IPCC Extension field only
IPCC Extension field only appears when you integrate UCCX system to CUCM, if you don't have UCCX installed then you  will not be able to configure IPCC extension as there would be no point of it.  Why do you want it set?
Chris
Is the drop down menu showing
Is the drop down menu showing up but there is nothing to select? If so, are there any devices associated to the end user under associated devices?
Or is there no IPCC extension drop down box, if so do you have UCCX integrated to CUCM?
Chris
Dear Chris, There is no menu
Dear Chris,
There is no menu for IPCC extension only there is seen primary extension, in which i have selected a primary extension.
i have  600 user device profile whose UDP is associated to controlled profile and extension mobility profiles in their user id and i have only 50 user without UDP and their phones are associated to thei user id
no i don't have any UCCX, but still i want to know is this normal.???
thanks
Chris
Dear chris,so this is normal,
Dear chris,
so this is normal, only when the UCCX is integrated then only we will be able to see the IPCC extension options
thanks
Indeed.Chris
Indeed.
Chris
122
