Directory Number Database Confusion
I have call manager 6.0 running on a publisher and subscriber. Things are generally working as advertised except for one problem with duplicate directory numbers (DNs).
The problem appears to come up when I get a request to move a DN from one site to another. The process I follow is:
1. add the DN to the requested phone
2. assign the DN on the new phone to the new partition
3. go back to the original phone and remove (dis-associate) the DN from it.
This process appears to create two DN instances in the database, one with the new partition, one with the old partition.
When I go back and clean up (delete) the orphaned DN I get and error (Unmapped Exception null) but the record appears to get deleted.
Has any body else seen this behavior?
Is there a different procedure I should be following to move DNs?
Is there a database maintenance procedure I should be running?
1 ACCEPTED SOLUTION
Green
Re: Directory Number Database Confusion
You may check CSCsk07400 and CSCsj95732 which are duplicated bugs you may upgrade to latest 6.1.2
Green
That's not exactly the behavior I'm seeing but it's close enough to call it highly probable. Thanks for the help
179
