Directory Order
fultont
Is there any way to change the order of directories displayed when pressing the directory button. I want to switch selection #4 and #5.
1. Missed Calls
2. Received Calls
3. Placed Calls
4. Intercom History
5. Corporate Directory
5 Replies 5
Chris Deren
Sorry, with Appliance based CUCM you can not change it nor remove any of these.
HTH,
Chris
Chris,
I would assume then that since I'm running CCM 4.2(3)SR1 a not appliance version that it's possible?
Tim
you can locate the ASP/JSP pages and simply modify the order, keep in mind that this is not supported.
Chris
Anonymous
Not applicable
Intercom History will be removed in the next official release of the phone firmware for the 41/61.
If you need it removed immediately you can open a TAC Case to request an ES.
Anonymous
Not applicable
Specifically reference bug ID: CSCsk99117
