Community Member
directory services
dear sir
I m using CCM 5.1.and i have configure URL directory parameters. i can see corporate directory/personal directory option when i press directory button.
but when i search user in corporate directory it says no record found.
could u plz help me out.i m using CCM default directory not AD etc.
Silver
Re: directory services
IN CCM Admin under User -> Corporate directory, did you add users?
Also fill in the extension field. Not 100% sure it's required but while you are in there, do the Device Association to associate the user's phone device to their userID.
Community Member
sir
i have already add users , and some of extension are associate with user Id's also.
I have tried with user mangement/ End user and with user/phone add options.
i cannt see any option in CCM admin user->corporate directory in CCM 5.1.
when i search in corporate directory its say no records match.
Community Member
Have you been able to resolve this issue ? I tried entering the telephone number under the end user configuration and it worked just fine.
Community Member
thanks radhesh
but i m still unable to resolve this issue.
i have tried same with CCM 6.x. but same problem.
131
