Community Member
disable callwaiting beep on CME
All, I have a client that wants to disable the callwaiting beep when a call comes in. I have seen where you can disable the ring, but I have not seen where you can disable the call waiting beep. Do any of you have any idea how it can be done, or if it can be done? Thanks for your help.
1 ACCEPTED SOLUTION
Re: disable callwaiting beep on CME
You could do this using the 'no call waiting beep' command under the DN in question.
See also:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1115896
/Mao
See also:
/Mao
Community Member
Thanks. That helped. I appreciate it.
1296
