05-11-2012 08:23 AM - edited 03-16-2019 11:07 AM
Do you know the command to strip the CNAM for outgoing calls, currently I have CUCM <---> H.323 GW with 4 PRI (two telcos), using primary-ni and dms100.
I think the comand is under the serial interface.
Note I want to strip the CNAM not the Caller ID.
The goal is that when I make a PSTN call from my IP Phone the PSTN user doesn't see my name (or company name) just the company number.
Thanks in advance.
Carlo
Solved! Go to Solution.
05-11-2012 09:29 AM
Carlo,
Try
no isdn outgoing display-ie
Under the ISDN D-channel
Something like this
interface Serial0/0/0:23
noisdn outgoing display-ie !
Alex.
Please rate useful posts.
05-11-2012 09:29 AM
