Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Disable Corporate Directory on CCM 5.1
Is there a way to remove the corporate directory from the directories? The user should only see the missed calls, answered calls, placed calls and the personal addressbook.
Best regards
Manfred
Re: Disable Corporate Directory on CCM 5.1
I do know that in CCM 4 you can just change the URL that the directory points to under Enterprise Parameters>Phone URL Parameters>URL Directories. Not sure if the same applies to 5.1
This applies to 5.1 too. But in 5.1 there is a additional Personal Addressbook "behind" the directory button. If I change the url to an undefined link, the corporate directory and the addressbook leaves. My goal is to keep the personal addressbook and delete the global directoy.
162
