02-01-2007 03:40 AM - edited 03-14-2019 07:49 PM
I just want to know if it's possible to disable CDP on IP phones.
If yes, is there a procedure?
02-01-2007 08:32 AM
I am affraid is not possible to disable CDP on the phone itself, it has to be done on the
port the phone is attached to. Please enter command "no cdp enable" and that should do
it.
02-01-2007 08:38 AM
Thanks for your reply.
I know i can disable CDP from cisco switch but our IP phone are not connected to cisco switch.
02-01-2007 08:39 PM
No way to disable CDP in IP Phone directly afaik.
