Disable or prevent corporate directory access on 89xx / 99xx phones
I'm trying to restrict Corporate Directory access for a few phones that are located in public zones (LAN or VPN)
On old models like 7975G it was possible putting a dummy IP address (http://127.0.0.1/ccmcip/xmldirectory.jsp) on the Device External Data Locations Information itself, then overriding the Enterprise Parameters values.
For 89xx and 99xx, whatever the value I put on the device, Corporate Directory is still reachable.
Any idea ?
JC,
Manish Gogna
Hi Jean-Christophe
In addition to what you have already done, you need to change the parameter 'Services Provisioning' on the Phone configuration page to 'External URL' and then save and reset the IP phone. let us know if it works.
Manish
Manish Gogna
Hi Jean-Christophe
Manish
That's it !
I've never paid attention to this parameter which value is Default.
Thanks for support.
