Disable Pulse Dialing on FXS port
Hello
A customer is having problems with analog phone that are connected to FXS ports on a VG224 (SCCP). The phone is dialing using DTMF. Unfortunately after gonig off-hook the phone sends a pulse dialed "1" to the VG224 (see attached log). Is there a command to disable pulse dialing completely on the VG224 or is it possible configure a delay so that (pulse dialed) digits in the first 500ms will be ignored?
Any input is welcome and many thanks in advance
Kind Regards
Stefan Christen
Hall of Fame Super Gold
Re: Disable Pulse Dialing on FXS port
I don't think it's possible to do that.
Hi Paolo,
For the sake of completeness: Disabling Pulse Detection should be supported in a release that's soon available.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsy16039
1397
