disable tone on hold timer with H323 gateway
Does anyone have a way to disable the tone on hold beeps for a UCM 6.1 using H323 gateways?
Is using a "silence" audio source the only way?
thanks
Rob
1 ACCEPTED SOLUTION
Re: disable tone on hold timer with H323 gateway
Q. How do I disable Tone on Hold (ToH)?
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item09186a0080094766.shtml#q21
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
so you need to have slience audio source to "fake out" call mgr..
thanks for the info link
rob
220
